Poll: The Best Brad Nails Are:
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    nova scotia, canada
    1,522
    Default Re: Brad Nails Recommendation
    casey your right, ive had that issue with generic framing clips..
    it has to do with the angle of the clips not being right for the gun itself. they wont feed correctly
  2. #12
    1,384
    In this case the angle was fine, but the sticky binding tape was clogging the slot the nails feed into; the spring was not strong enough to overcome the debris and advance the next one to the firing pin.
    But yes, the proper clip angle is crucial. As is the head shape and the spacing.
    Un-favorite framing gun: The older Hitachi that was plastic-collated, and spit little chunks of the plastic back at you!
    Casey
  3. #13
    nova scotia, canada
    1,522
    what about the paper collated hitachi. we have 3 of them and they just wont die. not only that their the only gun ive used that can sink spikes into lvl, glulam and timberstrand. every other gun ive used leaves the nails anywhere from 1/4- 1/2" proud
  4. #14
    Dec 2013
    10
    thanks for tips
