Results 1 to 10 of 11
    32
    Default Boiler on the fritz?
    I have a (probably original) hot water radiant baseboard heat natural gas boiler system. I came back to a cold house and a non-stop running boiler this weekend. I am not sure why this is happening, but I have a few clues as to what the cause might be.
    First, every now and again, when the boiler kicks on, it doesn't have the same pleasant sound it typically does. It literally sounds like a high powered blowtorch. It is unnerving to be around it during this time. This happened shortly after my gas line was moved. I hired a company to move it so I could put in a patio.
    The PSI is at 20 and the temp on the boiler states 180 -- I believe this temp is low? Air has been purged from the system and weak heat emits from the baseboards.
    Weirdly, hot water tank seems to be doing the same thing. Could we have a natural gas issue? The line was last touched 6 months ago and it was fine since.
    I replaced a small section of copper with pex about a month ago. I couldn't buy a small section of the oxygen barrier pex (a buck a foot for a minimum 300ft), so I just used normal pex.
    I appreciate any help regarding what I may have going on. Perhaps it's time for a new boiler.
    South*East
    1,257
    Default Re: Boiler on the fritz?
    180 is not low. There are many things that can be causing your problem.
    1-air in system
    2-bad circulator
    3-zone valve if you have more than one zone
    4-electrical problem (thermostat,relay transformer)
    John
    32
    Thanks John.
    1. I do not believe there is air in the system, but I will go around and open the air release valves. It has been fine for the past month or so.
    2. My circulator pump appears to be pumping. Water is hot at the beginning and end of the line (just not AS hot as it once was) and I do not hear anything different from what it has always sounded like. But since I have never messed with it, I would guess this is the closest of any of your other possibilities.
    3. The zone valves are manual twist valves. I have never touched them. Could sediment be blocking them?
    4. How might an electrical problem show itself? I know I can start up the boiler and pump and shut it off at will from the thermostat.
    Does any of this additional information help narrow down the issue?
    Feb 2013
    The thumb, MI
    54
    If your water heater is doing the same thing it sounds like the pressure regulator on the meter was damaged in the move. Don't waste any time getting that looked at.
    Feb 2013
    The thumb, MI
    54
    Re the circ. pump. Often the sound of the gas burner drowns out the sound of the circ. pump so it's hard to tell if it's running. Here's an old mechanic's trick: Take a long screwdriver and press the metal end against the pump flange and press the plastic handle against your ear. The sound of the pump running should then be obvious.
    32
    Thanks.
    Guy - If I'm ever in Romeo you will have to show me that trick. Evidence is pointing to a bad circulator pump, but I would like to rule out everything else before I put one on order. The current model is a Bell and Gossett series 100, 1/12th HP.
    The gas company will be out on Thursday to check the gas pressure.
    One outlet from the boiler is skin-singeing hot. I follow it 30 feet in the basement until I reach where it goes up and it becomes luke-warm. It will still put out heat at the baseboards, but the house won't get up over 61, and the boiler has to run constantly. I have it turned off until this problem is fixed.
    I don't see any other evidence of a bad circulator pump -- no leaking, no unusually loud noises. Pump appears to be pumping. Could these slowly decline and that is what I am seeing?
    Can anyone speak to the electrical components of the boiler and if perhaps there could be an issue there?
    Thanks!
    South*East
    1,257
    On the type pump you have there is a spring coupling between the pump and motor that you can see spinning if it's running.
    John
    32
    It looks like there are a few parts inside the pump spinning, so perhaps the pump is not the issue?
    I'm stumped. Perhaps time for the experts to have a look. My last attempt will be to recharge the system -- maybe buildup somewhere is restricting flow or air? It just blows my mind, the pipes are scalding all through the system, but the house doesn't get hot. Like someone went through and stole all my aluminum fins.
    South*East
    1,257
    Are the lines hot at all of the baseboards? If so then you have may have a problem with the design of the system. (Not enough baseboard) If the lines at the baseboard are not hot your problem is air.
    John
    Feb 2013
    The thumb, MI
    54
    If all the pipes are warm--but not as hot as they used to be--then I still think the problem is the high gas pressure. That can cause the flame to lift off the burners and is terrible efficiency.
    Let us know what the gas man says when he visits today.
