    Dec 2012
    Default Radiant Floor Heat.. Several Questions
    Just bought an old farmhouse in NW Ohio. The only heat source is currently a wood stove in the front room. No furnace or duct work. It is a 1.5 story approx. 1400 sq. ft. We are gutting the walls down to studs. The bathroom, kitchen, & utility are approx. 6" above a slab. The remainder lower level has a crawl space. With exception of the bathroom, we are installing wood laminate flooring throughout the lower level and trying to restore hard wood floors on the upper level.
    We are looking into an outside wood boiler with radiant floor heat. My fiance keeps hearing negative responses to this and changes his mind. I am liking how efficient they are supposed to be. The fact that there will be less dust (son with allergies & asthma). And the comfort difference I hear about.
    We would love to do geothermal (8 acres of land) but can't afford the price of installation.
    His arguments for forced air being a better choice...
    1) If there were to be a problem with pipe (PEX) in floor on the slab portion... we will have to tear up floors to repair.
    2) He gets opposite opinions from others as far as efficiency and cost effectiveness vs. forced air. Still using outside wood burner.
    3) More expensive to install than forced air.
    4) Takes to long for radiant floors to heat up. During spring & fall months when it is turned off during daylight hours.
    5) How do we cool in summer time?? Do we still have an added expense of putting central air & duct work in? Some say it's still worth it to install both. Are there other cooling options? The heat can be miserable in this location during summer months. This is the big question I am stumped on.. have no solution to back my opinion on going with radiant floor
    Any help, recommendations, experience.. would be greatly appreciated!
    Dec 2012
    New London County, CT
    124
    Default Re: Radiant Floor Heat.. Several Questions
    You did not say if any other sources or energy are available. Is the electric panel 200 amps to support what you have and the A/C? Nat Gas or propane?
    Once you know these you can decide if some hybrid can be put together.
    Forced air with a good electronic filter is a good choice if the correct energy is available, like not electric. You could use the radiant floor with a split A/C and maybe not need to install ducts.
    Dec 2012
    I'm not sure how many amps our electric panel is. We have some electrical that needs redone also. Previous owner has a 100 lb propane tank hooked up for a small wall heater. The hot water and everything else is only electric. We will see today what the electrical panel is.
