Results 1 to 10 of 11
Thread: Sewer question
    73
    Default Sewer question
    Hi guys
    Every year Denver water comes by and "cleans" out the sewers. Not sure what they do on their end. Every year I have problems with this issue.
    I have a drain in the basement that is used in case the hot water heater leaks. It works fine regardless how much water I run down the drain either from the kitchen just directly above, or pour down the drain in the floor.
    Every year, the water guys come and over the next day or two I end up with water problems. If I run my dishwasher, or let a sink of water drain, the water backs up into the basement from this drain. I don't have a snake long enough so I end up calling a professional plumber. This year I just can't afford it. Of course my conversations with Denver water in the past have lead me nowhere. They claim that because it is on the line to my house it is my responsibility and they won't do anything. They claim that the water has been backing up for months and I just now realize it.
    I need advice on what I can do to either clear the drain myself or what I can tell Denver water to make them fix the problem they created.
    1,004
    Default Re: Sewer question
    all i can recommend is a little exploration. hire a plumber that has a snake camera. he can run the camera from your house all the way to the main sewer line in the street. maybe he'll be able to shed some light on the problem.
    7,592
    You're on your own on this one. Your water company won't lift a finger to help you, no matter what causes your problem. But if your problem goes away after you snake your line, then do just that.
    You may want to invest in a good 75 ft drain cleaner, and if it's too short, install a clean-out along the way.
    South*East
    1,246
    What happens when you flush your toilets? Are the sewers in your area both sewer and storm water? Something isn't right if the toilets don't also backup into the basement. Both the toilets and the kitchen sink should run into the same line.
    John
    Mar 2013
    WI
    112
    As said above,the city will not do anything if the clog is on your side of the point where your main meets their sewer,which I'm guessing is in the street.
    How far from your main clean out to the sewer? I measured mine and it is a 90' run. I have 3 large trees in my front yard and their roots grow into the main. About once a year I have to go rent a cable to clean out my main. It is 100' 1" diameter power cable for cleaning out main drains. My local rental place has 100,75,and 50' for rent. It cost me about $40 to rent,and is a pretty nasty job,but a heck of a lot cheaper than calling a roto-rooter type place. I've never had luck with those hand cranked snakes when it comes to 4" main line,I only use those on sinks.
    (And yes,I've tried root killer!)
    7,592
    Quote Originally Posted by 67drake View Post
    Have you ever run a camera in your long main line?
    I bet your line is busted in a few places, and if it is, replacement (not relining) would be the answer.
    Mar 2013
    WI
    112
    Thanks for the tip.
    Nope,I'm too cheap! I always just cleared it out myself. Never hired somebody with a camera. I'm only going to be in this house 2 more years,so I have my fingers crossed it won't need another cleaning.
    I wish I would have thought of that 16 years ago when I moved here. It would have been worth my while to look into that.
