    Mar 2012
    Default wood spacers in patio
    The wood spacers between the concrete panels in our patio are rotting out. What can I put into the crevices to reduce trip hazard? Sand, gravel, polymeric sand?
    Most of the panels are 3"x3". A few are 6'x4'
    Thank you.
    8,004
    Default Re: wood spacers in patio
    You can do a few things, replace the wood, inlay brick, or fill with colored cement.
    I would not recommend gravel or sand because those items won't stay in the hole, they will continually be scattered across the patio and be the bane of your existence.
    7,762
    I agree with spruce, except forget about replacing with new wood. Use masonry product only.
    Mar 2012
    Thank you both. I really like the brick idea,but (as I neglected to mention) the spacers are 1x2 on edge so the gap is too narrow.I think red concrete would look really good.
    Would mortar hold, or should I tint quickcrete (or something similar)?
    Thank you again.
