    Feb 2013
    Question Water heater anode rod replacement
    When replacing a water heater replacement rod, I understand you should wrap the threads with teflon tape as a leak preventative and also to make it easier to remove the next time, but doesn't the tape insulate the threads from the tank and prevent conductivity between the rod and tank? Should a small section of the threads be left untaped to make conductivity or does the tightening of the threads compress and tear the tape enough to make conductivity at a few points?
    1,002
    Default Re: Water heater anode rod replacement
    the teflon tape is fine and will have no effect on the anode rod at all. there's no electricity running through the rod.
    I do teflon tape AND plumber's dope.
    1,002
    i do too, especially on PVC universal traps, makes it sooooo much easier to tighten up
    Feb 2012
    92
    Not going to effect it at all the electrolisis is inside the tank in the water not the rod itself.
    Ben Franklin Plumbing
    372 D St
    Salt Lake City, UT 84104
    (801) 416-3522
    http://www.benfranklinplumbingut.com/salt-lake-city-ut/
