Results 1 to 9 of 9
    Mar 2013
    Unhappy Crown Molding in Cape Cod upstairs bedroom
    Hi all, I really need some assistance here. I am a first time home owner and am also not a carpenter by trade. If you can help, please speak in lamens terms so I can understand.
    I bought a 1972 Cape Cod home. I took on the project of installing Crown Molding on the entire main level. After some frustrations, I was able to acquire the skill and finished the main level no problem- angles and all.
    Now the frustrating part: The Upstairs! The bedrooms in this Cape Cod has slanted ceilings. I'm not sure how many of you are familiar with them, but they are an absolute pain when it comes to angles. I can post a picture if need be. Anyways, I tried for two hours last night to figure out the angle that runs into the 45 degree wall, and then the angle for the piece that comes off that wall and heads the other way. As I mentioned earlier, I installed crown on an entire level of my home at many different angles, and I tried every one of those angles, with coping, and so forth-no such luck.
    I should also note that I installed 4 1/4" Crown throughout the main level and I am simply using 1 1/2" Bed Mould to break the ceilings from the walls. It seems so simple because they are smaller pieces, but let me tell you, it isn't.
    Has anybody ever attempted this task? What angles am I looking at? How in the world can I get the corners to line up with a 45 degree downward angle?
    Please help!
    Thanks!
    1,002
    Default Re: Crown Molding in Cape Cod upstairs bedroom
    i've done that before. three walls get the crown molding, the angled wall doesn't get any at all. the crown dies into the sloped ceiling.
    Mar 2013
    Unhappy Re: Crown Molding in Cape Cod upstairs bedroom
    Thank you for the reply. Really? Aw man I would hate to simply leave those bare angles with trim everywhere else? How did the end result look? I feel that if I walked into the room and seen molding like that, it would look unfinished to me.
    Also, where the window extends off the house (where the two angled walls come to) that is another flat space where I can lay the molding and then it would look really funky to literally have molding on 3 walls and then a small piece above the window but nowhere else.
    That probably reads confusing, but thank you for the response. I am going to waste another board or two tonight trying to figure it out; and, if I do- I will post back on what I did. I was so close last night...nothing a little caulk and paint can't make look nice is the way I look at it.
    Thanks again.
    Anybody else ever attempted this?
    MLB's solution is the simplest, though instead of just leaving the one wall blank, you paint "trim" there, basically, just paint a stripe the same color as the trim to give the eye the impression of something being there.
    Another method is to use corner blocks. These are 1" to 1-1/2" square blocks that are slightly longer than the trim is tall. Sometimes they have a decorative base, sometimes not. You install the blocks at each corner, which gives the trim something to but into other than itself. The longer angle cut on the trim is absorbed by the block.
    Yet another method is to cut pieces to make the corner transition. Go to youtube and search "vaulted ceiling crown molding", there should be plenty of vids on the subject to show you how to cut your way around those corners.
    Mar 2013
    I did in fact google my life away last night as I considered punching a hole in the wall. I have seen the idea of those blocks, but I am trying to envision how it would look. The exact spot that I am talking about has a three way intersection. Therefore, a block wouldn't really fit into the equation, unless it's one hell of an odd shape. I could lay the block on the edge of one wall and then come into it off the other wall, but it would be laying flat against just one of the wall's and I feel that would look mighty odd.
    It's kind of hard to put into words the way that this corner looks, so I apologize if it's confusing.
    I really don't like the idea of painting it either, but you are right- it is an option.
    I suppose it's back to youtube for more videos. I am sure I will figure it out with trial and error, but I have 2 full bedrooms to do (this being the first corner of 5 more yet to come- opposite sides too) and was hoping for the miracle answer I suppose. I will get it, it's just going to take some time.
    Thank you for your response.
    I'm having a hard time envisioning a scenario where three trim legs converge into one corner. There is no way you're going to get a good union with trim joints alone, unless all trim is symmetrical (such as a clover leaf ), and all laying flat on the same plane, and crown is neither of those things.
