    Feb 2013
    The thumb, MI
    54
    Default Cutting slab & laying insulated pipe
    An addition on my cottage is a slab on grade. It joins the original section of the log cabin which has the bathroom. I want the slab addition to be a laundry room so I need to run plumbing to the utility sink. I'm planning to rent a concrete saw & cut/break out a trench to lay insulated water pipes & drain connecting to the bathroom soil stack in the crawl beneath the old section. Are there any worries about cutting a slab in half like this? Are there any flaws in my plan?
    7,334
    Default Re: Cutting slab & laying insulated pipe
    Your plans looks good, but must be permitted by the city bldg dept, inspected and signed off by your inspector.
