Results 1 to 10 of 10
    Feb 2013
    The thumb, MI
    54
    Default What to do with uneven celing?
    I recently bought a vacation cottage and am planning many projects inside & out. The living room is a large "great room" about 27x19 with an 8-foot ceiling of 1/4" paneling nailed directly to the trusses, with foil-faced fiberglass insulation above. This paneling on stud is popular in cottages in northern Michigan--maybe because it survives winter shut-down. Mine is quite uneven and with no walls, beams or lights to break it up, it's pretty obvious.
    I'm thinking I can fix this 2 ways:
    1 - Correct the flatness by either sistering new joists to the old, or running furring strips perpendicular to the joists & shim those flat. then hang a new ceiling--probably t&g pine planks.
    2 - Hide the waves by breaking up the expanse some way. Thinking a coffered ceiling, fake beams, stucco...something like that.
    I can't see how I can FIX the problem without losing nearly 3 inches of height (3/4 fur + 3/4 plank + shims for maybe 1" error) so I'm more interested in ideas to conceal the problem.
    I'm open to any & all ideas. This is just a cottage so I'm looking for something I can do myself to keep the cost reasonable.
    nova scotia, canada
    1,522
    Default Re: What to do with uneven celing?
    install furring 3/4" furring strips to the underside of the joists and shim them as needed to create a flat surface
    Why not nail over it with some 3/4" bead boards?
    Jun 2009
    397
    You could look at the RC-1 Resilient Channel and 1/2 inch dry wall.
    Feb 2013
    The thumb, MI
    54
    OK I know I can shim and fur it flat. Looking for alternatives that wont cost me inches of height.
    nova scotia, canada
    1,522
    your not losing inches. your losing 3/4" you can sister 2x4 to the sides of hte joists but thats more money on material.
    if your ceiling is less than 7'6" i wouldnt worry about it. what im suggesting is done everyday by pros like myself and houston among others on the boards
    2,743
    Agreed that the 3/4 T&G is the way to go. Easy to do, looks nice, and it won't sag over time plus you won't miss the tiny lost height one bit.
    Feb 2013
    The thumb, MI
    54
    I really like the looks of a coffered ceiling in a large room. The ceiling is maybe one inch max from flat...+3/4 furring + whatever I put up = about 2.5". If I did the coffered ceiling I'd lose another 4". Looks like I cant do both.
    nova scotia, canada
    1,522
    if you do go with a coffered ceiling your going ot have to have a flat ceiling to start with. otherwise your margins are going to be all over the place from one section to another. . by furring down the ceiling first you'll have a much larger area to fasten the ceiling finish to
    Feb 2013
    The thumb, MI
    54
    margins ?
    My original hope was that a "busy" ceiling like this would hide the waves but nobody at all is suggesting I go down that road.
