    Feb 2013
    Default Cracked concrete
    I have a cement floor in my bathroom witch I am planning on installing tile, what is the best way to bridge that gap for tile installation?
    7,341
    Default Re: Cracked concrete
    For cracks less than 1/4" wide use concrete caulk, then tape/mesh over the crack.
    Sep 2009
    florida
    598
    LATICRETEŽ Blue 92 Anti-Fracture Membrane
    http://www.laticrete.com/architects/...upression.aspx
    Gizmo
    Hidden Content
    Hidden Content
    3,117
    If the crack is due to movement over a wood substrate, then you'll need to beef up the joists and or plywood to handle tile. If over a slab a crack isolating membrane will help, but you still have to honor the joint all the way through the tile assembly, which means locating a 'soft joint' over the crack OR a somewhat complicated 3 tile wide, very specific installation method.
    If you have vertical displacement (one side of the crack is higher than the other) then there are other issues.
    For all things tile, head on over to the John Bridge Tile Forum where you can start your own thread, post pictures and get answers specific to your home.
