    Feb 2013
    Default old work hangars
    I have been unable to locate joist hangars for rough sawn lumber. Old house with actual 2" joists not 1"3/4. Has anyone used these, where did you find them?
    3,155
    Default Re: old work hangars
    Best to ask the folks who make them.
    Simpson Strong Tie
    7,723
    There are a few options.
    1. Have hangers fabricated and custom done for you.
    2. Use wider hangers (for double joists) and fill the gap with plywood, then use longer nails to fasten them together.
    3. Check Simpson LF209, or Simpson metric sizes.
    If It were me, I'd choose #2. But check with your local bldg dept.
    Sep 2009
    florida
    598
    Ck out Simpsons "HU Series" they are bent to your specs for rough sawn lumber. There special order from any big box usally in few days.
    USP will do the same thing
    Gizmo
    Hidden Content
    Hidden Content
    1,369
    LVL hangers are good for 1 3/4". The inspectors in our area permit us to use full height 90* corner hangers wherever a u-shaped hanger won't work.
    Casey
