    25
    Default hardwood floor height
    We plan to install oak hardwood floors in our kitchen. There is a plywood subfloor. How much height should we plan on for an underlayment plus hardwood?
    Default Re: hardwood floor height
    Depends, are you nailing the floor down or is it a floating floor?
    If you're nailing, then underlayment may be required if the subfloor is not thick enough to resist movement or hold a nail sufficiently.
    If it's a floating floor, then you will be adding 6mil plastic vapor barrier, 1/8" foam sheet, then the floor is assembled over the top.
    What does the flooring manufacturer recommend, because ultimately their guidelines are what matter.
    3,201
    What Spruce said plus;
    add any leveling compound that may be needed to flatten the floor.
    Sep 2009
    florida
    598
    Thumbs down Re: hardwood floor height
    Check the Dishwasher hgt opening. Adding to much to the floor might cause problems getting it back in
    Gizmo
    Hidden Content
    Hidden Content
