    Feb 2013
    Default creating dual zone for hot water baseboard heating
    I am renovating a house with hot water baseboard heating that I would like to split into a first floor zone and basement zone. I only have one thermostat upstairs....is it possible to run the basement off a different thermostat?
    South*East
    1,253
    Default Re: creating dual zone for hot water baseboard heating
    Yes you can but it requires a lot more then just two thermostats. It will also require piping changes, two zone valves or a 2nd circulator.
    John
    Jul 2009
    172
    I agree with John; you can make 2 separate zones using zone valves or zone circulators with 2 separate T-stats; as noted, the piping arrangement between the 1st floor baseboard and the basement baseboard has to be re-piped so that the heated boiler water will flow thru the 1st floor circuit when the 1st floor T-stat calls for heat, or will flow thru only the basement baseboards when the basement T-stat calls for heat; or, will flow thru BOTH 1st floor & basement piping circuits when BOTH T-stats are calling for heat.
    I would recommend the Taco 570 Series model zone valves if you decide to do this.
    Do you plan to do this yourself, or have a heating contractor do it???
    http://www.youtube.com/watch?v=o9eB8sHaVns
    http://www.youtube.com/watch?feature...&v=oKmToQTzow4
    http://www.diy-resources.com/images/176-0.jgp
    http://highperformancehvac.com/boiler-water-loops/
