    Feb 2013
    Default removing stopper from bathroom sink
    The 'stopper' is stuck in my bathroom sink....the metal one. It is no longer attached to the lever that raises and lowers it. It is so tight water will not seep out. Any way to remove this without removing pipe?
    3,201
    Default Re: removing stopper from bathroom sink
    Remove the screw ring that holds the stopper in place and wiggle a flathead screwdriver around.
    Feb 2012
    92
    Yep exactly as houston said under the sink were the lever sticks out unscrew it and put in screwdriver if the lever is still intact simply reach under and push up or down on lever and get it to open.
    Ben Franklin Plumbing
    372 D St
    Salt Lake City, UT 84104
    (801) 416-3522
    http://www.benfranklinplumbingut.com/salt-lake-city-ut/
