Results 1 to 9 of 9
    Jan 2013
    23
    Default Salvaging Cedar Fence Boards
    One of the projects my wife wants done in the next couple years is to replace a 200' and 70' run of cedar fencing, replacing it with vinyl to match the rest of the property. The fence boards are your typical 1/2" x 6" x 6' pieces, most are in decent condition but are weathered. I hate to cart it all to the recycle dump and was wondering if its worth it to buy a bench planer and resurface the boards? I'm not sure what I'd use the wood for, but thought someone on the forum might have an opinion on this thought.
    Default Re: Salvaging Cedar Fence Boards
    Generally speaking, they are useless in their present condition. For you to spend time and money to restore them, will be good resources down the drain. When you take them apart, you'll see even more damages.
    However, there could be someone near you who may want to use them to repair an existing fence. You probably have around 550 boards in your 270' of fence. If you could salvage half of them, then find a buyer who would pay you 50 cent each, you'll make about $135 - worth the trouble?
    If yes, find that buyer.
    Jan 2013
    23
    Thats what I needed to hear. It doesn't sound like its worth the trouble. Thank you for the feedback.
    You wouldn't want to use a planer either, one missed nail or screw or staple or rock, or dirt in general will dull or destroy the planer knives in a heartbeat. A thickness sander would be the better option if you were so inclined to try to salvage the boards into useable lumber.
    As for salvaging for fence repairs, I would see what the going price is for new, then cut that in half for boards that are in excellent condition, still, is it worth the work for a few hundred bucks? The formula to figure it out would be:
    $ return divided by time invested = value of time spent
    As DJ points out, it's a lot of work for little gain. Do you have a fireplace or wood stove? How about a backyard fire pit? If so, then cut up the fence and burn it yourself, it will be worth far more than what you could make trying to clean it up and sell it. you don't have to worry about removing fasteners either, just burn them with the wood. You can sift them out of the ash with a magnet if you use the ash on your garden, or just pitch the whole thing into the garbage and be done with it.
    Using these boards for firewood may be a wise solution, UNLESS they are painted/stained, in which case you shouldn't burn them.
    Jan 2013
    23
    Since both of our fireplaces are gas inserts, I can't use the wood. When possible, I like recycling materials but I do agree after seeing the comments, that it is better to send it off to the recycling plant. It is a lot a material to store and it really doesn't sound like its worth the effort. My neighbor is a big time recycler and will be disappointed and I hate to break his heart, but I have better things to do with my time.
    You could always offer it to the neighbor, let them come dismantle the fence and take it for free, saves you the time, effort, and expense of doing it yourself.
    Jan 2014
    Advertise them for free on Craigslist or Freecycle, someone will take them. They could be used for building compost bins or perhaps doubled up for raised bed gardening.
    Apr 2015
    Another decent use for them is in the garden. Rip into 1x2s for trellis, 1x1 for stakes. Unless the fence is very old, it's likely solid.
    Weathered wood here can go for a premium as 'barn board' I've seen picture frames done with it, bird houses/feeders, used for entire walls in 'man caves'. Seriously enough of a premium that its almost worth buying new wood, and setting up a system to weather it.
    In passing: I've never seen fence boards as thin as half inch. 5/8" maybe?
    In terms of processing: Keep it away from the planers, but by all means, buy a Freude 'demo' blade in one of the higher tooth counts (about once a year I see them on sale for under 10 bucks.) I have a 7.25" thin kerf blade I use on my table saw when I'm making stakes out of pallets (as a tree farmer, I go through a couple thousand stakes a year) If it hits a nail, it's no big deal. Cut a couple thousand stakes and throw the blade away.
