Results 1 to 9 of 9
    Feb 2013
    Default How to install oak treads on brick steps
    I have an addition on the back of my house. The old brick steps that used to lead outside, now lead down to the addition or den of the house. I would like to install oak treads over the brick steps but am not sure how to best attach the treads to the brick. Any ideas would be greatly appreciated.
    nova scotia, canada
    1,522
    Default Re: How to install oak treads on brick steps
    countersunk and counterbored tapcons so that the holes can be plugged.. or tear out the brick stairs and have stringers cut and installed
    3,188
    The above suggestion will work, but before that I'd try a few well placed gooobers of PL Premium. Done correctly, the PL dries to rock hard in an hour. If they don't come loose in a week, they will be there for life. Do make sure the steps are as dust free as possible before applying the PL.
    AT worst they come loose and you can do the screw down method with the old PL acting as a leveler.
    1,383
    Concrete masonry can maintain enough moisture content to make your treads swell and cup. I'd use a 2-part polyurethane rubber concrete sealer/adhesive system meant for gluing down engineered flooring to below-grade slabs.
    Casey
    nova scotia, canada
    1,522
    1 hr for pl to set up... ive never seen that happen and ive used hundreds of tubes of the stuf.. and if the treads arent mechancially fastened theres still a chance they will come loos not to mention shift while its setting up. all finished stairs we do no one walks on them for 12 hrs
    3,188
    if you pull the PL to add air to it, the stuff cures real fast. At least down here in South Texas
