    Default Installing a shower niche
    We have taken out the tub and are putting in a tiled shower. Need some pointers on how to install a niche between the studs. We were told it was best to wait until the tiling is done up to the bottom of where we want the niche located, so it would look good and not require tile cutting. We will need to put in some support pieces between the studs, but it is a problem to do it through a hole in the concrete board! Any suggestions for how to accomplish this would be much appreciated.
    7,762
    Default Re: Installing a shower niche
    It's not hard at all. You need to cut the cement board to the size of your recessed niche, and then you support blocking will be easy to insert and fasten between the two studs.
    3,179
    You can also glue the blocking into place.
    What waterproofing method are you using?
    Feb 2013
    Texas
    15
    Cut your supports that will be on top and bottom to size . Pre-drill two holes on the top side of the bottom support down and at an angle toward the back and into the stud . For the top support
    drill from the underside into the stud and a angle to the back . Screw into the predrilled holes slowly but with firm pressure . You can attach a handle to the board such as a for a cabinet to help hold the board in place .
    Feb 2013
    Have a look at the new schluter shower prefab niches. Saves a lot of time and they're waterproof!
