    Feb 2013
    Default Rremove basement toilet & tie into line for 1st floor toilet
    We need to add a 1st floor 1/2 bath. My idea is to remove the toilet from the basement (which nobody uses)and install a new 1st floor toilet above, literally using the existing (basement) plumbing... can I run the new toilet waste line into the existing waste line below if plan my bath to be directly above old basement camode? (if so / can I do same with vent system below?)
    or am I way off in my thinking?? thanks
    Default Re: Rremove basement toilet & tie into line for 1st floor toilet
    If you do everything to code, I don't see why you can't do this.
    If you are new to plumbing and want to DIY, at least have a plumber look at your work. Check with your building dept whether you need a permit.
