Results 1 to 9 of 9
Thread: water heater
    Feb 2013
    New York
    Question water heater
    Brand: State Select gas water heater 40 gallon,
    Model # PR640XCVIT & Serial # F06A000549
    The water heater locks, and doesn't heat the water.
    UNIT IS LOCKING (not heating water)
    **lights A & B turn on...(which means system is lockout) -
    there are 4 solutions on the trouble shooting-
    1- gas is off or too low to operate
    2- hot surface igniter not positioned correctly
    3- low voltage to the water heater
    4- electric polarity to unit is incorrect
    The unit have been working over five (5) years, never had issues till know. I have to disconnect and reconnect the water heater, which heats the water for a couple of hours, then it locks again (no hot water); have been doing this since December.
    I hope is clear
    Thanks
    7,635
    Default Re: water heater
    I read your posting twice - and still can't tell what you are writing about.
    Can you re-write it more clearly, more accurately and more precisely?
    1,964
    Is it an electric water heater or a gas water heater? What brand.
    Feb 2013
    New York
    Question Re: water heater
    I hope is clear
    Thanks
    3,155
    Maybe the exhaust is blocked?
    When was the last time the crud was flushed out of the HWH?
    Feb 2013
    New York
    Thank you
    The exhaust is not blocked, we check
    What is the crud & how we could flushed it out of the HWH?
    3,155
    The crud that builds up are the minerals in the water supply.
    Watch this video.
    Look for the water to run clear.
    7,635
    Take a look at your burner, make sure the mesh is in good condition, look at your flame sensor - it could be dirty (use a fine sandpaper to clean it), make sure there is no debris on the sensor.
    Hope this helps.
    1,964
    It could be the control panel itself. In the rush to make everything "digital" things have gone overboard. They add cost, increase complexity and rarely contribute anything. My electric water heater has one of these panels too and so far, it has been the only source of failure with the unit.
    Check the warrantee on your unit. I got my replacement panel for free under warrantee but next time, it will cost me $108. Just like my stove and dishwasher, both have "digital" controls and the digital control boards have been nothing but trouble. I want my dials back.
