    Oct 2008
    10
    Default wallpaper paste removal
    My home was built in 1917 with plaster walls in very good condition. I believe wallpaper was put on walls in 1964. The wallpaper was easy to remove but the paste....have read about vinegar/water solutions; any other suggestions?
    2,919
    Default Re: wallpaper paste removal
    We usually start with plain warm water and some liquid dish soap and soak the walls as much as possible, coating the wet wall with sheet plastic if needed.
    1,739
    All wallpaper pastes are water soluble, some more than others.You have to get them wet and keep them wet until they loosen. Once softened, they can be wiped away with a sponge. Often they need encouragement with steel wool or 3M scrubby pads.
    I always used a garden sprayer to apply the water. I would tape plastic to the bottom of the wall to form a trough from which I would wipe up the water coming down the wall. Don't get too far ahead, as once the paste softens, you want to get it off before it dries down again.
    6,323
    I know you'll try to do a good job in removing the paste, unfortunately, there will be some paste left on the wall, no matter what you d or how many times you clean the walls.
    When you prepare the wall after the cleaning, use a good primer before you paint, to stop the remaining glue from bleeding through.
    1,739
    I agree with dj1 about priming. Try as you might, you will miss some paste, especially since cellulose pastes are clear. They cannot be seen, but only felt due to their slimey feel.
    Also,If you tint your primer to the finish color, you will probably get by with only one prime and one finish coat.
    1,134
    Vinegar is pretty good for breaking down the paste, but on real plaster it also dissolves the lime and etches the walls. I'd go with a detergent/ammonia blend.
    Casey
    102
    I like to use DIF to remove the paste work great I use hot watere and mix it a little strong. Usually gets it all off. But is must stay wet.
    I have applied it using a roller in a paint pan.
