    Apr 2009
    Default Garden: Help with new sump line pop-up install
    I had a new sump pump and line installed that twilights in the culvert at the end of our driveway. The water has caused a muddy mess, and I need to know how to fill in around the pop-up where the grass used to be, and with what. I am looking for an attractive and permanent fix.
    Thank you so much for your advice.
    OKC
    247
    Default Re: Garden: Help with new sump line pop-up install
    You should be able to put some pea gravel around the drain then some top soil then plant sod on top of that.
    Can you post pictures of what you're dealing with? The cure will be different depending on if you've got a gravel or cement driveway and how it all connects to the culvert/ditch area.
