    Jan 2013
    12
    Default Drywall/Plaster/Fireplace/TV question
    Sorry for the confusing title.
    What is the best way to add a tv over the fireplace?
    The home is from the 1920s. it is all plaster. I don't know if there are studs framing the fireplace.
    Should I rip out the plaster, frame the fireplace out, then matchup the drywall to the plaster?
    102
    Default Re: Drywall/Plaster/Fireplace/TV question
    You can use a stud finder or drill tiny holes to find the studs then patch. No need to go through all the work of demo to hang a tv.
    Question: why do you want to hang your TV over a heat source?
