    Apr 2012
    143
    Default Replacing A Toilet Fill Valve
    Sorry for posting before doing my research . . .
    Tonight, I discovered that a Fill Value is spraying water when filling; the water is exiting through the flush handle.
    I've replaced a Fill Valve before (with a flex supply hose), but this new to even if it's standard.
    This one has 1/4" chrome-finish solid pipe, withe compression fitting on the fill valve and the supply shut off value.
    I assume I can't reuse the 1/4" solid pipe, even with a new compression fitting to a new fill valve tower (the fitting looks like it's also a reducer).
    I want to the keep the supply valve, which is also compression fitted to the inlet pipe from the wall.
    What should I do (besides dj1 telling me to call an expensive plumber in No. VA).
    Thanks.
    3,158
    Default Re: Replacing A Toilet Fill Valve
    They make flex hoses available at the big box stores. They run about $5 Be sure to get the right one on each end. It can be confusing.
    7,762
    t_manero,
    You don't need to call an expensive Washington DC plumber for this type of work. A skilled handyman will do. Besides, don't you want to stimulate the economy a little bit?
    Regardless, the 1/4" tubes are slowly vanishing, very few use them. Choose a flex, as HR said. Make sure you get one that say "closet".
    You can do it, they can help.
