    Jan 2013
    Default Bathroom remodel
    How small is too small for a occasionally used 3 peice guest bathroom?
    3,188
    Default Re: Bathroom remodel
    You can get a tub down to 4 feet wide, squeeze in a toilet and sink in 7 foot long, for a total of 28 sf, but your local building codes may differ. Smaller bathrooms aren't good for handicapped, and those with mobility problems (sports injuries) and those with vision impairments.
    Feb 2013
    Oklahoma City, OK
    Quote Originally Posted by mbwalter View Post
    Tub required?
    If space is an issue, look into a space saving shower. Those can get pretty small.
    I guess the real question is: How big are the guests?
    7,762
    Too small is when an able person feels cramp, can't turn comfortably and hits something to his right and left.
    Figure 18'-24" for a lavatory, 30" for a toilet, 3'x3' for a tiny shower stall and 24" front clearance and you get approx 25 sf. Don't forget the door.
    That's tiny. For a handicapped person you need different measurements.
    Always check with your local building dept.
    Apr 2012
    143
    What are you trying to accomplish ?
    The most efficient design that I've seen is what I had in a previous house and the Embassy Suites bathroom.
    Picture a rectangle about 10' x 5' -
    One 5' side is a 60" tub w/ shower hardware.
    The other 5' side is double (small - 18") basins.
    Between the two 5' sides is a standard toilet up aginst a 10' wide wall.
    The door is opposite the toilet (you stare at the toilet when the door is open).
    Standard in-wall medicine cabinet(s) on the ends of the double basin with full mirror.
    With shower curtin closed, 2/3 people could use the room w/o embarrassing themselves. And if you can raise the ceiling, either soaring or cathedral, the space won't seem cramp.
    If you want to see how many people can ride a VW Beetle, then try this :
    Picture an airline lavatory.
    Build it like a shower with a drain in the middle, and plumb it with necessary piping. After inspection, you can configure it as a Wet Room by adding overhead or wall shower hardware, good for occasional use by one person, and you can get to about 16-18 sqft footprint, but no tub.
    I had a bigger version of this done. When the inspector asked why there was a drain in a 1/2 bath, we said "In case the toilet overflowed, much easier for clean-up." Afterwards, the contractor pull the glued on tiles and installed the shower hardware that was already plumbed -- it was California so heating wasn't a problem.
