    Jan 2013
    Default Getting grout sealant to seal
    I'm having trouble sealing the grout on my bathtub/shower wall. The tiles about about a foot square synthetic with 1/4 inch lines of grout. We sealed them when we moved in about 7 years ago with no problem. The grout began showing signs that water was getting in (i.e. it got dark when we took a shower) in an area about 4 tiles high on the side and 3 under the showerhead about 6 months ago.
    I first tried to seal it again about 2 months ago using the cheap stuff that came in a bottle with a brush applicator. After putting 4 coats on over a week or so, the sealant was still just going right into the grout whenever I put it on. My wife got tired of not using our shower so I gave up and water just seemed to soak right in.
    I bought 511 Impregnator a couple of weeks ago thinking that maybe I needed something stronger. I have put 3 solid coats on with a sponge brush using a third to half of the bottle. There has been some improvement, but grout is still not sealed in the majority of the area (i.e. the sealant just soaks right in turning it dark).
    Any tips on why the sealant isn't sealing? Or any tips on a better way to apply it? I try my best to catch it with the sponge as it runs down the wall and brush it back up or into the grout. I am following the instructions re: waiting 48-72 hours for it to dry between coats etc.
    One thought I had is that we previously used a bleach cleaner to clean the tub and grout. Our water turns the grout orange after is allowed to seep in for a while, so we used the bleach cleaner to get rid of the color. Before I started sealing with the 511 Impregnator I also used as special grout cleaner, hoping to flush out any bleach that might be in there still. Could that be the problem - bleach built up in the grout breaking down the sealant as I apply it?
    My wife wants her shower back.
    Default Re: Getting grout sealant to seal
    First let me tell you that there is no "lifetime sealant". Even the best sealant will not last 7 years.
    Secondly, you did not prepare the wall for a new sealant. The instructions on sealant bottles tell you how to prepare.
    Now, you have to clean the tiles and grout and clean them well. Follow every step of the instructions precisely. And then apply your new sealant.
    BTW, don't buy that cheap stuff, you know it will fail you every time.
    511 is an excellent sealant and with the proper preparation will have worked well.
    NO sealant makes grout waterproof, and none of them claim to make grout waterproof.
    Your shower should be waterproof before the tiles and grout are applied, as tile + grout + sealant + cement board + thinset are NOT waterproof.
