    Jan 2013
    5
    Default What is this tool?
    What is this tool used for? On the left end is a round piece of wood which spins. In the center is a hinged piece with two counter sunk holes which I assume is to fasten the tool to a table or wall. On the the right end is shaped like a spoon but round with a little hole in it. The round piece of wood which spins is worn along one side along the length so it is not totally round anymore. I would appreciate any ideas. Thank you.
    Attached Files Attached Files
    Sep 2012
    Boston
    1,002
    Default Re: What is this tool?
    i don't know but it looks similar to the tool that's used to clean the hooves of horses
    1,375
    It's not a tool, it's the bellows pedal for a melodeon, circa 1870. With an hour of research, I could probably tell you the manufacturer.
    Casey
    7,969
    Quote Originally Posted by Sombreuil_mongrel View Post
    Casey
    Well good God, man! Get to it!
    Jan 2013
    5
    Well, I should of asked a long time ago, I have spent hours trying to find out what it is. I thank you very much and will ask about a few other mystery items I have.
