Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    Jan 2009
    Taxachusetts
    136
    Default Re: water not up to second floor
    Could be hot side cartridges clogged even more so if the shower/tub is not a single handle. Have you disconnected the supply lines underneath to see if your getting water to that point? You did add shutoffs on the 2nd floor while you had it drained, right?
  2. #12
    Apr 2009
    6
    No I didnt. The cold water is fine. I will check on the water valve and the hot water heater. It also seems to be leaking again-toilet. There should be no way it is leaking.
