Results 1 to 10 of 12
    Oct 2012
    6
    Default Cracked Kitchen Sink Pipe
    Hello - I noticed one of the pipes under my sink has a small crack in it. It's not too bad as I've got a pail under it and that catches it. It's a dual sink and the one that's cracked is the one that goes from the second sink into the main pipe. I just wondering what a ballpark figure would be to have someone come out and repair this? I don't know anything about plumbing and would want it done properly anyway. I know the details are limited, but any help is greatly appreciated. Thanks.
    3,120
    Default Re: Cracked Kitchen Sink Pipe
    You can fix it yourself for right close to $6.
    A plumbers will start over $100. If you want to stimulate the economy, call the plumber. Otherwise, remove the cracked pipe and take it to the hardware store where they will have replacements. You might have to cut it to length, but that's easy and you can just copy the length of the other one.
    7,344
    If you are not sure, watch youtube videos. You will need basic hand tools and good hands. Still not sure? call a handyman.
    Oct 2012
    6
    Thanks for the replies. I'm sure it's not rocket science, but I don't have much experience with doing this stuff and I would want to do it the right way. Do you have any links for the YouTube videos? Thanks again.
    7,344
    Let me teach you how to find things:
    Go to youtube.com
    Click the subject you want.
    Watch vids.
    Here's a better advice: hire a handyman and get the job done.
    How to find a handyman? Go to craigslist or similar classified.
    1,794
    As DJ suggests, a handyman will be much cheaper than a plumber. This type of work is simple and probably wouldn't require a permit unless you are in a condo with an uptight HOA.
    1,301
    Put down the crack(ed) pipe. Somebody had to say it...
    A lot of times the chromed brass tubing corrodes/dissolves from the inside leaving just a tissue-thin chrome plating. It can stay intact until bumped.
    You'll need a pipe wrench to break the fitting at the wall, but trap replacement is pretty low-skill. If it still leaks, keep the bucket!
    Casey
    5,941
    Here is a video on how to install a sink drain, it includes a GD but the fundamentals are the sane.
    http://www.youtube.com/watch?v=ykikb_7Fxx4
    3,120
    This is why we like plastic drain pipes.
    Oct 2012
    6
    Go to youtube.com
    Watch vids.
    Are you always this much fun to be around?
    Thanks all for the replies. As much as I hate to admit it, it probably looks like it's beyond what I'd like to do and like I said, I prefer that it gets done right. I'll probably find someone to do. I can't imagine it'd be too expensive. Thanks again.
