Thread: Epoxy bedroom
    Apr 2009
    Default Epoxy bedroom
    My home is on a cement slab, w/ no basement. In my kids rooms there is carpet over the slab. As an inexpensive way to redo their floor, I thought about putting the epoxy flooring used in garages. Can I put ceramic tiles(at a later date) over the epoxy?
    Sand Springs, OK
    Default Re: Epoxy bedroom
    I don't think you can tile over the epoxy.
    My kids rooms are carpet and padding over concrete slab too. we've thought about using those interlocking tiles they use at work sites but snap and lock garage tiles would work too.
    Honestly, I wouldn't ever tile a child's room. There are too many falls in there and tile is hard. Then when they fling the baseball bat around the room, or drop their marble based academic trophy or drop the jar of food they snuck out of the fridge and it hits a tile well you'll have to replace the broken tile.
    I speak from all the stuff that has happened in my kitchen.
    Debby in Oklahoma
    Aug 2009
    I don't think you could tile directly over epoxy, but you could lay laminate flooring or wood flooring on top with no problem.
    Good luck!
    2009 kitchen remodel warrior
    asbolute black granite
    Antique White Hidden Content
    Travertine 18" x 18" floor tiles.
    It looks Great!!
