Results 1 to 10 of 15
    Jan 2013
    23
    Default Switchable Outlets
    While swapping out electrical outlets I replaced two that were tied to switches and must have omitted a step because I can't get the switch to work with either outlet. Both outlets on each are live, but I'd like to hook them back up to the switch. I used replacement outlets that were similar to the ones I replaced. Did I miss something? White to silver, black to ****, ground to ground???
    Jan 2011
    Columbiana, Alabama
    843
    Default Re: Switchable Outlets
    Did you break the brass tab off between the "hot" screws? If not they both stay on.
    One half of the receptacle should be connected to the constant "hot". The other goes thru the switch.
    Jan 2013
    23
    Quote Originally Posted by The Semi-Retired Electric View Post
    No I didn't. I tried to wire the new outlet identical to the old one, but missed that step. Good scoop. I'll check out YouTube to see if there are any videos showing this.
    Jan 2011
    Columbiana, Alabama
    843
    It's real easy, using a pair of long nose pliers, just work the little brass link a few times, between the two brass screws on the receptacle and it will break off.
    1,904
    Unless you've got a really strange setup, don't break off the tab on the neutral side.
    Jan 2011
    Columbiana, Alabama
    843
    Very true, that's why I said "between the BRASS screws".
    1,904
    I never go by the color of the screws; I always go by the width of the slot (wide is neutral; narrow is hot). I once found a brand new outlet that had the brass and silver screws swapped.
    Jan 2013
    23
    Success! I pulled the outlet out of the box and checked my wiring. I cut the tab between the two brass screws and it works. I knew my wiring was correct, but learned something new. Thank you for your assistance.
    Jan 2011
    Columbiana, Alabama
    843
    Quote Originally Posted by bobrien1775 View Post
    Great glad it worked out!
    Oct 2012
    Houston, TX
    318
    So is it standard to only have the outlet be half switched? I am in the process of changing out my cloth wrapped romex to 12-2 w/g and want to make sure my one switched outlet is done right.
    Looks like I need to buy even more 12/3 to go along with the switch loops I need to improve upon in my bathroom.
