    Iowa
    20
    Default duct work for furnance
    does duct work ever get loose ? cause it feels like it is vibrating the floor which in turn vibrates my bed when I sleep at night. How can that be fixed ?
    1,661
    Default Re: duct work for furnance
    The problem is more likely to be the blower in the furnace. It may be out of balance or need to be cleaned. The blower should be installed with rubber "shock mounts" to isolate vibrations; these mounts may have deteriorated and need to be replaced.
    Iowa
    20
    thanks so much
    Iowa
    20
    Default Re: duct work for furnance/ solved
    problem solved , there was a piece of insulation that had gotten in the blower .... NO VIBRATION yippee thanks yall
