    78
    Default Third floor HVAC return
    Hi, I have a third story attic space that I'm converting into a bedroom. My gas furnace and A/C unit is in the basement of the house. I have run two ducts up to the third floor space. Heating the space isn't too bad. I have an electric baseboard installed plus with heat rising, etc., it stays pretty nice up there. Cooling in the summer is next to impossible. I need a window A/C unit to keep it comfortable. Heres my question. I know the value of a "return" to the units in the basement. The only place I could place one is in the floor of the space where it will meet up with the return from the 2nd floor. Should I put this return in? I notice that the rest of the house mostly has returns up high on the wall. Would a floor return simply return my cool air back to the basement in the summer? The option of a furnace/AC unit on the third floor is not an option at this point. THanks for any suggestions.
    3,158
    Default Re: Third floor HVAC return
    Here in the deep south, high returns are favored. Up north, low returns are favored. Where are you located?
    78
    I'm probably in the "middle". Southern NJ. We get winter temps in the teens (as in the last few days) and summer temps in the mid- to high 90's w/ high humidity.
