    Dec 2012
    Oklahoma
    Exclamation Danger, Will Robinson
    My house, built on a concrete slab, doesn't have a ground wire! What is the easiest way to ground the electricity???( If there is such a thing as an easy way to do this!!!)
    Jan 2013
    13
    Default Re: Danger, Will Robinson
    This is definitely one for a licensed electrician. There are options for installing a ground that don't involve tearing up your walls, but you want to get a professional opinion.
    Steve Rogers
    Remodeling University
    The Best Remodeling Education Available
    Hidden Content
    Hidden Content
    2,025
    Are you absolutely sure it doesn't have a ground wire? I can't imagine a house that has been built on a slab that doesn't have one. Just because you have two prong plugs instead of three prong, doesn't mean that there isn't a ground wire. Have an electrician inspect it for you.
    1,002
    i'm sorry but there's no way i can believe that your electrical system is not grounded...
    do as kieth said, have an electrician look at it
    Jan 2011
    Columbiana, Alabama
    843
    I wonder if the OP means he doesn't have ground rods. If he has a slab they may have used the rebar in the slab for a ground.
    A quick look in the SE panel could settle the issue.
    Jun 2010
    Chicago
    30
    Is your wiring in conduit?
