    Houston
    Default Flat panel TV episode sourcing
    What is the source of the electrical/cable receptacles in this episode. I looked in my Lutron Electrical catalog but couldn't find them, specifically the recessed electrical/low voltage device with the surge protector, described by Scott at the close of the segment. (behind the television they removed from the wall in the shop)
    Thanks
    Txn8
    Houston
    6,006
    Default Re: Flat panel TV episode sourcing
    Not sure which one was on the episode but here is one
    http://sewelldirect.com/WallBlade-by...With-Power.asp
    Oct 2012
    Houston, TX
    318
    Two-gang recessed media boxes can be found a places like home depot and monoprice.com. Surge protected receptacles can also be found at the same locations.
    Houston
    Talking Re: Flat panel TV episode sourcing
    Thanks for the replies. I actually found an acceptable one @ Home Depot.(shocked) I bought 4 for a home I'm constructing.
    Texn8
