Results 1 to 10 of 10
    Jul 2008
    49
    Default What tool is recommended for cutting door threshold?
    Hi All,
    If you wanted to cut the entire metal or wood door threshold nosing flush with the door side casings what tool would you use...Ive been thinking purchasing the multi purpose cs450 dual saw...the only thing that concerns me how would you prevent the blades from scraping and damaging the casings...
    http://www.dualsaw.com/products/dual...day-cs450.html
    Sep 2012
    Boston
    1,002
    Default Re: What tool recommended for cutting door threshold
    i use a sawzall all the time for that job.
    Jul 2008
    49
    HTML Code:
    Wouldn't that be hard to cut a straight line...
    Sep 2012
    Boston
    1,002
    if you've never used or rarely used a sawzall it might not be the best choice. you can use a circular saw to get rid of about 3/4 of the material if you're comfortable using one. if you have no experience you might want to buy, rent or borrow a multi tool. it will just take a while to make the cut. if you do decide to use a multi tool make sure that you make your cut at an angle of 10 degrees or more. if you make a straight down (nicely vertical) cut, when you're done you won't be able to pry up one side because it will catch against the other piece.
    Jul 2008
    49
    Hi MLB...
    Not sure I understand the part "make sure that you make your cut at an angle of 10 degrees or more. if you make a straight down (nicely vertical) cut, when you're done you won't be able to pry up one side because it will catch against the other piece."
    Also what do you think about the CS45O Dual saw...
    Thanks
    Sep 2012
    Boston
    1,002
    i've seen them but i've never used one. i believe rockler makes one too. it won't make a full cut like a sawzall or multi tool will because of the round blade. wouldn't it be the same as using a circular saw?
    imagine you're kneeling at your threshold, with it going across from left to right in front of you. now if you cut straight through the middle with any saw, you'll have a vertical cut line going straight up and down. now when you try to pry up either the left or right side it's going to bind against the opposite side making it difficult to get up.
    now imagine making the same cut but instead of making it a straight up and down cut, you tilt the bevel of the saw to, let's say, 10 or 15 degrees. now the cut through the middle is still straight across the middle but the cut is beveled to one side. now you can easily put your pry bar into the cut and pop up one of the sides without having the other side of the threshold get in the way.
    Jul 2008
    49
    I think I found the saw Im looking for...
    The Straight Flush Saw...
    http://www.straightflushsaw.com/index.html
    Sep 2012
    Boston
    1,002
    that saw isn't available yet plus it won't make the cut you need. it looks like it will make about 95% of the cut as will any circular saw. why would you buy that saw for $495 when you can buy a cheap circular saw to do the same thing for less than $100.
    Jul 2012
    United Kingdom
    I use dovetail saw because the handle is straight and gripping is easy.
    7,723
    tonyc56,
    When it comes to tools, any tool, it all depends on your intended use and the price.
    A recip saw is one tool that can be used in dozens of occasions - perfect for the typical homeowner.
    The two tools that you found will not be as good for your purpose.
    If you are so worried about damaging the casings, why not remove the threshold and cut it on your work table?
