    Jan 2013
    Default Hot Water in One Bathroom/Lukewarm Water in the Other
    We recently bought a home this past March.
    We have two bathrooms, both on the second floor. They are at a distance of really, just a couple of feet. The bathroom in the master bedroom gets hot water; I mean, comfortably hot and just right. The bathroom in the hall however, gets barely lukewarm water. The water was a bit of an issue then but manageable.
    Now that it's winter, oh boy! Are the kids complaining!
    Both bathrooms were redone at the same time with the exact same tub and faucet fixtures.
    Can anyone help me troubleshoot? Why is 1 bathroom getting hot water but the other gets barely lukewarm water when they're both barely 3 feet apart?
    Thank you!
    5,793
    Default Re: Hot Water in One Bathroom/Lukewarm Water in the Other
    It could just be an adjustment of a temp control valve.
    South*East
    1,208
    It could be a bad cartridge in the tub or shower mixing valve. They will sometimes allow the cold water to mix with the hot.
    John
    198
    I agree with the above 2 posts; if it is possible to talk to the previous owners, you may be able to get some insight as to how the hot water lines in the 2 bathrooms are piped, & perhaps the location of any shutoff valves/mixing valves/anti-scald valves, etc.---otherwise you will have to do a "detective search" starting at the boiler/hot water heater to determine how the pipes are routed up to the bathrooms & how they make any branches/diversions, & if there are any shutoff valves anywhere along the way.
    The site below has images of the various mixing valves/tempering valves widely in use for hot water piping---the older piping often has a round, black plastic handle on the valve---often over the months/years gunk/crud clogs up the mixing/tempering valve---so if you find one, open & close it several times to see if you can loosen up the flow of HW---you can get a much larger image of each valve by clicking on that particular item so you can see the wide variations in HW bathroom/water heater piping that exist.
    Also try running the HW faucet that ISN'T producing much HW for 5 or 10 minutes full blast to see if that clears out the line.
    http://www.google.com/search?q=image...GUo4C4Cw&ved=O
    cfuqsAQ&biw=1024&bih=768
    1,591
    That's nothing, the old house I grew up in had the water heater on the opposite side of the wall from the bathroom sink. It took over a minute for hot water to get there.
    There was about 30 feet of pipe between the two. You see, it had been subject to countless remodels. Eventually Dad & I replumbed the entire house and fixed those annoyances.
    Jan 2013
    Thanks all for the insight.
    Both bathroom tubs use a single-handed shower knob. For that one bathroom with the issue, the hot water in the sink is just fine. It's just the tub.
    The house was a short sale so no possible way to speak with the previous owners. Being it was a short sale, we had to replace both tubs in both bathrooms.
    After reading everyone's comments and doing a bit more researching,I'm starting to suspect it might be clogging at the stem or a bad shower cartridge? Either case, I hired a contractor to do all that work in my bathroom and I am far from happy if that's the case and it's starting to feel like that is the case.
