    Jan 2013
    Default Utility Sink Issue
    Basement sink is filling up with what I believe is sewage water. Initially, the level would rise then decline... sometimes low enough to apply drain cleaner.
    If this was a drain blockage issue why is it now overflowing? No faucet water has been introduced. Guidance sought.
    Image uploaded to:
    Default Re: Utility Sink Issue
    What is the weather like right now in your area? It is not uncommon for water to back up in the lowest drains when the water table rises or the municipal systems are inundated.
