Results 1 to 10 of 12
    Jan 2013
    Dublin, Ohio
    Default Brand new replacement windows leak cold air!
    We recently replaced all of our leaky Double Hung windows with "Renewal by Andersen" Double Hung.
    The installers removed the old sashes and stops and inserted the replacement unit in the hole, and
    centered the window unit in the opening. I saw them plumb & shim the sides of the window directly behind
    the pre-drilled screw holes in the jamb. (actually they didn't use the middle screw hole.)
    The team was being very frugal with the foam insulation between the units frame and rough opening, they
    only insulated the top and sides, leaving the area between the sill and the bottom of the replacement
    window totally open. Once they completed the installation; the only thing blocking the air flow
    underneath is the outside metal flashing and the wooden Stool on the inside.
    I was very concerned by the incomplete foaming job but they assured me that they HAD to do it that way to
    prevent condensation. In their own literature it mentions improper installation can occur if the
    installer does not insulate fully between the window and the rough opening!
    Now that it is below freezing our house is cold and drafty. Tonight its 32 degrees outside and using my
    infrared thermometer the walls and frame around the middle of the window is 64 degrees... But the window
    Stool measures 50 degrees. Some windows are even colder, you can feel a draft, I've even held a lit
    candle close to the window seams and the flame bent at the draft.
    QUESTION:
    Is it ever correct to leave the entire bottom uninsulated?
    Sep 2012
    Boston
    1,002
    Default Re: Brand new replacement windows leak cold air!
    the only possible reasons i can come up with for not insulating under the window or fully around the window are the following.
    1. poor workmanship
    2. laziness
    3. cheapness on the installers part
    Jan 2013
    13
    It sounds like you had installers who didn't know what they were doing. Many of the window replacement companies use subcontracted crews for their installations and their standards can be low.
    The window needs to be properly insulated all around to prevent air infiltration. There is no good reason not to do this.
    Get them to reinstall the windows with a different crew. If that doesn't work, report them to Angies LIst and the BBB
    Steve Rogers
    Remodeling University
    The Best Remodeling Education Available
    Hidden Content
    Hidden Content
    Jan 2013
    Dublin, Ohio
    Thanks for the info so far, I can post a photos of the lower sections tonight.
    They did use professional low expansion foam in a cartridge gun.
    I thought they were wrong leaving the entire underside wide open.
    ON the outside they bent metal and inserted on side on the slot on the replacements frame and caulked down the other side that touches the cedar window wrap. There is a 1x1 trim that sits on the stool against the new window and its cold to the touch. I feel cold air blowing in under the curtains.
    The inside comfort level (at the same thermostat setting) from our leaky 22-year old peachtree windows is about the same as I'm dealing with now.
    I do have a photo I took while i was hanging Christmas lights. To my horror this is how I found the top section of a second floor window (sorry I'm new here and cant link the photo, but if you cut and paste it into a browser you can see)
    columbusrestauranthistory.com/window.jpg
    Was the guy too lazy to go back down the ladder and cut a top section that was the correct size?
    Tennessee
    2,025
    This may or may not work. If you bought these windows from an authorized Anderson dealer, then contact Anderson windows directly and speak to a Customer Service Representative. They may apply pressure on the dealer to get this job done correctly.
    If you bought the windows from a big box store and used one of their contractors to install the windows, then contact the customer service at the store you bought them at, again, they may want to police their subcontractors.
    Jan 2013
    Dublin, Ohio
    I have been debating on calling the HQ or the local office. The team really pushed us to rate them a '10' and begged us to call the local office directly if there are problems.
    My issue is the supervisor was the one that refused to put any sort of insulation under the windows... I pushed the workers to do it and they had the super come out and he ultimately said no. I am concerned that all the installations in this area are compromised if that is how they do them all.
    Another Thing:
    Although all of the windows are cold, around the bottom, I've noticed a few of the replacement frames were installed are skewed, instead of a perfect 90 degree rectangle, some were installed as a parallelogram, so when the window is closed and locked the one side is raised 1/4" and the wind blows in. I have to put painters tape on the gap so my toes don't freeze.
    Tennessee
    2,025
    Go straight to HQ.
    1,522
    not caulking the nailing behind the sil of the window on the outside is done so condensation can run out.. not foaming is just plain lazy.
    i can see an installer running a thin run of foam initially when the window is set so that the foam doesnt cause the window frame to bow which can cause the window to not operate properly.. i do this, once the first pass sets up about 40 minutes later i go around the window again.. its very common for window and door installers to over do it with foam.. a week later they have to come back and service the operator because it wont open or close properly
    Aug 2012
    31
    You have to insulate everything; there are no ways about it! It doesn’t seem like a top-notch professional installation. I’d suggest you call Anderson or the guys who installed everything for you and speak to the customer service guys right away! Improper insulation will raise your cooling and heating bills, so get it done at the earliest. Even we had drafty old windows that needed to be replaced. Got our new windows from Champion Windows Dallas. So far, no complaints!
    Sep 2009
    florida
    598
    Call the company that hired the installers and tell them what your explaining to us. If you get no where with them call the local Anderson rep. Im guessing you had them done through Home Depot because Lowes isnt an Anderson supplier.
    Gizmo
    Hidden Content
    Hidden Content
