Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    Jan 2012
    Yoo-taw
    10
    Default Re: Frozen PEX lines in a soffit.
    So, I ended up removing the foam pipe wrap insulation, and applying heat tape to the copper/PEX lines inside the house, and insulating the heck out of any soffit space where it would allow in any draft or cold air. So far, so good!
    Thanks for the help!
    - Oz
    EOD - Initial Success or Total Failure!
    DISCLAIMER: All thoughts and ideas put forth in this communication are sole property of the voices in my head. 1998-2013 - 'The Voices' (TM). All rights reserved.
  2. #12
    Jan 2012
    Yoo-taw
    10
    Problem's been fixed! Once I got the heat tape installed along the copper pipes, taped down, and the entire thing re-insulated, I haven't had a problem yet!
    Now the only question I have, is how to keep power to the heat tape. Currently it's on an extension cord running back into the unfinished basement. I'd considered running Romex out to a GFCI receptacle in between the floor joists, which will give it some fault protection, and also theoretically act as a 'seasonal switch.' I thought of doing a home run straight back to the panel too. . . but I'm not sure what would be to code.
    Any ideas? I'd post pictures, but I need to increase my post count first. . .
    - Oz
  3. #13
    1,906
    Quote Originally Posted by EODOswald View Post
    Just remember that all electrical connections (including outlets) must be in an "accessible" location, which could be behind a removable access panel. If it requires a saw or sledgehammer to access, then it's not accessible.
  4. #14
    Jan 2012
    Yoo-taw
    10
    Absolutely follow what you're saying. Thankfully, my access to the soffit has been through a removable panel from underneath the soffit, which also gives you access to the area between floor joists where the trap for the tub is and the PEX lines I had trouble with before.
    - Oz
