    Dec 2012
    Default rust-color stain in toilet
    I have 5 toilets in my house and only one toilet has a rust-colored stain in the bottom of it that I can't remove without removing all of the water, letting the stain dry and chipping it out. I can't understand what causes this, why it's only a problem in one toilet, and would love some advice on what is causing this stain and how to remove it more easily.
    Oct 2012
    Houston, TX
    319
    Default Re: rust-color stain in toilet
    Possibly a length of galvanized or iron pipe in your cold water system near the toilet.
    By chip out, do you mean with a chisel? If so you are severely reducing the life expectancy of your toilet. Try a pumice stone on a stick instead, can be found at some grocery most home improvement stores.
    7,359
    Start by checking the water supply nipple (coming out the wall on the left side of the toilet above the baseboard).
    Is it a galvanized nipple?
    Dec 2012
    12
    Great post!
    Thanks for sharing.
    thanks,
