    Dec 2012
    Question Anode Rod Corroded
    I moved into a new house in August 2012 in Arizona, and quickly noticed air spurting from the showers and faucets when the hot water was turned on. When I turn the thermostat down on the hot water heater, the spurting air seems to be less. I contacted Bradford White, the hot water heater manufacturer and they advised it was either air in the lines or a faulty anode rod. The developer's plumber did come out in December and replaced the anode rod. The old anode rod was caked with mineral deposits. I have attached a picture. The plumber said he has seen ones like this but only in hot water heaters in service for several years. Could there be another explanation for the extreme amount of build-up? Is it possible the plumber initially installed an old heater in my new house, or is there something wrong with the water supply? I do have a water softener installed, and it is "city" water (not a well).
    Attached Files Attached Files
    Default Re: Anode Rod Corroded
    To find the age of the water heater, or the date it was manufactured, check the label on the water heater. If you can't de-code it, call Bradford White's customer service.
    Plumbers buy water heater in bulk, to get a better price. It's entirely possible that the heater sat in the plumber's storage for a while.
    Change the anode rod now, and see what happens to it in the near future. If nothing like what you described happens to it, there is a chance, though I don't want to believe it, that the plumber installed a used heater without telling you. I used to change a lot of heaters, and sometimes I came across a good used one that I kept for my rentals. but I would never install a used heater in a customer's house.
    Another thing you can try is a whole house water filter system.
