    Jan 2012
    Abbeville, Louisiana
    Default shower repair??????????
    I have a tiled shower and backed by my kitchen with NO access to the plumbing that I can find. Everything needs replacing it's so old, 1960's model home.Do I demo all the tile to get @ pipes? Please help!
    Default Re: shower repair??????????
    If everything got to go, then gut the bathroom to the framing and start anew.
    2,024
    Something is going to have to give here. If you don't want to tear out the tile, then maybe you can get to the plumbing from the kitchen side. Open the doors on the lower cabinets and if you see drywall, then that can be ripped out. If you see the back of the cabinet, then the cabinet will probably have to be removed, but that might be a better alternative to damaging a perfectly good tile wall. But if the tile isn't perfectly good...
    Dec 2012
    12
    Great post!
    Thanks for sharing.
    thanks,
    For complete information on shower replacement head on over to the John Bridge Tile Forum. There you can post pictures and get answers specific to your project.
    Oct 2012
    29
    What??? Its too old definitely you should change it!!
    1,901
    If your shower was tiled in the '60s, it might be a good idea to tear it all out and start over. If there's any sign of moisture intrusion, you're not saving any money by not retiling. There were some good tile jobs back then, but most were not... materials and methods have improved dramatically in the last several years.
    There are still hackers out there that will install using old methods or worse, but the options now available to good installers are much better than they used to be.
