    Jan 2012
    28
    Question Two 240V 1500 watts baseboard heaters on one circuit double pole 20a breaker
    Currently we have two 240v 1500 watts baseboard heaters on single circuit protected by double pole 20amp circuit breaker.
    Is it safe to turn on both the heaters at highest heat at same time without any risk?
    Jan 2011
    Columbiana, Alabama
    843
    Default Re: Two 240V 1500 watts baseboard heaters on one circuit double pole 20a breaker
    Sure, the combined load is 12.5A and a 20A circuit is allowed up to a 16A continous load.
    Just be sure all the connections are made up properly.
    Merry Christmas
    Jan 2012
    28
    Question Re: Two 240V 1500 watts baseboard heaters on one circuit double pole 20a breaker
    I just wanna make sure that they are double pole i.e total 40 amps and that is ok correct?
    MN
    455
    Quote Originally Posted by vikasintl View Post
    No! If your double pole breaker is labeled 20 amps then it's 20 amps for each leg and doesn't add together to equal 40 amps.
    Chicago, IL
    162
    Just to clear up a common misconception.....
    On is On and Off is Off.
    The baseboard heaters use the same 1500 watts of electricity whether you set the thermostat at 60 degrees or 90 degrees. At 90 degrees, they just stay on longer, using the same 1500 watts all the time.
    It's not the same as a portable heater which might have low-medium-high settings.
    HTH
    Dave
    1,906
    Quote Originally Posted by Dave357 View Post
    That's right. A thermostat is an on-off switch, controlled by temperature. When it gets too hot, it turns off. When it gets too cold, it turns full on. It's not a gas pedal.
