    Dec 2012
    Default How to remove metal trim from windows and closet
    Hi, I am having an issue with removing metal trim around windows and the closet in one of the bedrooms. I am trying to decide if it is worth removing it and then trimming around the windows or if I should just board up around the metal trim and then use new wood trim. Let me know if guys have any ideas.
    I am working on getting a photo uploaded. Having a little trouble with size limit.
    Thank you,
    Brian
    5,804
    Default Re: How to remove metal trim from windows and closet
    You can e-mail Pictures to me jackson_l_mcdaniel@yahoo.com abd I will post them for you. Include TOH PICS in the subject line a nd a link to this thread or your TOH username.
    5,804
    If you are talking about drywall corner trim you would need to cut the skim coat about and inch in from the corner and scrap the skim off the corner trim to remove it. If it were me I would leave in place and box in.
    5,804
    Here is the Op's photos
    It would appear from the photos you are talking about a metal window frame and a metal door from. You have the choice of boxing in the frame with wood or you need to replace the window and frame with a new window and remove completely the door frame.
    Dec 2012
    Jack thanks for the help.
