    Mar 2011
    6
    Default Shower Moisture Venting Question
    Hello, I have a newly installed Shower Vent/fan that just currently just exhausts the moisture into my attic.
    My Question is, can I link the SHower Vent to an Existing VERTICAL Vent Stack? I'm imagining just cutting the Vent Stack and put in a WYE ABS fitting, connect the Shower to the WYE fitting, and the air/moisture goes out the stack.
    Is this to code/legal? Will it work?
    The reason I don't want to go Horizontal and put in a new vent tube out of a wall is because I don't have a hammer drill and bit to punch a 3" or 4" hole in my exterior wall.
    Do I just bite the bullet and go Horizontal?
    In my mind it seems easier to go Vertical using a Vent Stack.
    Thoughts?
    Thanks guys!
    Nov 2012
    Santa Ana, CA
    13
    Default Re: Shower Moisture Venting Question
    The use of wet venting would eliminate the need for the individual vents. You can combine the vent of your sink, tub and toilet into a single one
    3,188
    This is a duplicate post and has been answered elsewhere
