    Question Bathtub Leak between first fllor ceiling & 2nd floor tub
    I think I know the answer, but I'd like opinions on how to fix a slow leak from a 2nd floor tub. No access panels available, and water spots are showing up on ceiling (drywall) of family room under the tub. Do I have to cut out a portion of the ceiling, fix the leak, then repair the ceiling? Or, is there an easier way to solve this problem? Help, please.
    Sand Springs, OK
    467
    Default Re: Bathtub Leak between first fllor ceiling & 2nd floor tub
    You said you know what you have to do. You are right.
    Take the damaged ceiling out, fix the leaky pipe and then put in fresh dry wall.
    Look out for mold though. Maybe you should hire a mold remediation place before you get started.
    Debby in Oklahoma
    This looks like a recent leak, as we never use that bathtub. The kids just used it when their bathroom was repainted.
    Jan 2009
    Taxachusetts
    136
    With kids I always suspect water getting by the shower curtain. Spray it with a bleach solution and see if it (the stain) comes back.
    Shaun
