Results 1 to 10 of 11
    Nov 2012
    Question hot-water circulation problems
    We have a hot-water-baseboard heating system that supplies our household hot water as well. About a year ago, the hot water in the shower became unavailable unless we concurrently ran the hot water in the washing machine or sink (same room). Eventually, we found that we could stop running the secondary hot water source once the shower was running well. When we turned off the secondary source, the shower ran full force. Suddenly, even this trick doesn't work. If we turn the hot water handle 1/3 on, we get a trickle of hot water. If we open 100%, we get none. This is a hot-water only problem. Cold water runs fine. Can anyone help?
    1,002
    Default Re: hot-water circulation problems
    sounds like you have to change the cartridge in the shower valve. pertty simple DIY fix. take a pic of your shower valve and bring it to the plumbing supply and tell them you need a new cartridge.
    Nov 2012
    I'm sorry I wasn't clear ... the hot water doesn't get to the tub faucet (and, therefore, doesn't get to the shower head either).
    Oct 2012
    Houston, TX
    318
    It still goes through the cartridge if it is a modern setup.
    South*East
    1,259
    Like MLB said replace the cartridge in the faucet. It sounds like it's a balance pressure faucet that the balancing spool is sticking.
    John
    What they said but I'll add;
    Try taking it apart and cleaning it first.
    We once had a customer with a similar problem, no hot water at the second floor shower. Seems a roofing type rock got all the way through the house plumbing, up to the second floor and had lodged into the hot water cartridge. It would rock back and forth allowing small amounts of water to flow if you were lucky.
    MN
    455
    Ditto on the cartridge for your balancing valve. I'm confused why this wasn't addressed a year ago?
    Dec 2012
    Two questions on this issue:
    before changing cartridge, do you need to shut off water supply?
    does changing the cartridge affect the force of the water?
    (our hot water comes out a little slower and drips some out of the water spout)
    Thanks
    1- yes. Shut the water off. > remove the cartridge > turn the water back on full force to flush out any gunk > turn water off > clean old cartridge if your re-using it, replace if not > turn water back on.
    2- If clogged, yes
