Results 1 to 10 of 11
    Nov 2012
    Question hot-water circulation problems
    We have a hot-water-baseboard heating system that supplies our household hot water as well. About a year ago, the hot water in the shower became unavailable unless we concurrently ran the hot water in the washing machine or sink (same room). Eventually, we found that we could stop running the secondary hot water source once the shower was running well. When we turned off the secondary source, the shower ran full force. Suddenly, even this trick doesn't work. If we turn the hot water handle 1/3 on, we get a trickle of hot water. If we open 100%, we get none. This is a hot-water only problem. Cold water runs fine. Can anyone help?
    Sep 2012
    Boston
    1,002
    Default Re: hot-water circulation problems
    sounds like you have to change the cartridge in the shower valve. pertty simple DIY fix. take a pic of your shower valve and bring it to the plumbing supply and tell them you need a new cartridge.
    Nov 2012
    I'm sorry I wasn't clear ... the hot water doesn't get to the tub faucet (and, therefore, doesn't get to the shower head either).
    Oct 2012
    Houston, TX
    318
    It still goes through the cartridge if it is a modern setup.
    South*East
    1,259
    Like MLB said replace the cartridge in the faucet. It sounds like it's a balance pressure faucet that the balancing spool is sticking.
    John
    3,201
    What they said but I'll add;
    Try taking it apart and cleaning it first.
    We once had a customer with a similar problem, no hot water at the second floor shower. Seems a roofing type rock got all the way through the house plumbing, up to the second floor and had lodged into the hot water cartridge. It would rock back and forth allowing small amounts of water to flow if you were lucky.
    MN
    455
    Ditto on the cartridge for your balancing valve. I'm confused why this wasn't addressed a year ago?
    Nov 2012
    I will take the hot-water handle apart tonight and see what I can find to "clean".
    I googled the cartridge to see if I could find a diagram, but everything was the single-handle control for the faucet. We don't have that. Our bath was put in about 1964, and it is two faucet handles (hot and cold) and the spigot with a pull-up knob to redirect water to the shower head.
    Why wasn't it fixed a year ago? Because I discovered the work-around of turning on the hot water in the sink to get the shower going, and I was inundated with childcare and eldercare.
    Thanks for the help so far! I really, really appreciate it.
    215
    This also could be caused by a TEMPERING VALVE that's become clogged.
    A tempering valve/mixing valve, usually situated close to the boiler, controls the temperature & amount of HW mixed with cold water that is sent to the shower & the tub faucet so that it doesn't scald the bather; consult the site below for variations of what they look like & see if you can find one on the HW line that goes to the tub/shower; try twisting the tempering valve knob back & forth, open & closed to see if you can loosen things up & get a better water flow to the tub/shower---the older TVs/MVs usually have a black knob.
    Try to trace your domestic hot water line (DHW) from where it comes out of the boiler----this is known as a "tankless coil" & is usually a round black 6" circular black plate embedded on the top front of the boiler, with a copper tube going in, and one coming out to the faucets that service the sinks, shower, etc.
    http://www.google.com/#hl=en&tbo=d&o...&bpcl=38093640
    Dec 2012
    Two questions on this issue:
    before changing cartridge, do you need to shut off water supply?
    does changing the cartridge affect the force of the water?
    (our hot water comes out a little slower and drips some out of the water spout)
    Thanks
