Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: outside doors
  1. #11
    Default Re: outside doors
    Quote Originally Posted by 3poodles View Post
    Hello I am new to this site but wanted to ask a question relating to exterior door prep and the standard for center to center (CTC) measurements if anyone can tell me what these are. I live in Canada but I would assume that the standard CTC is the same for US as for Canada but I could be wrong about that. thank you
    In remodeling, I like to have the door available and ready to install and calculate the rough opening from the intended door. Also, the measurements are in the plans.
  2. #12
    framiner add 2 inches to each dimension; the RO for a 36" door is 38" x 82", for contractor type doors. If you got something special, do only as DJ said and have the door in your hot little hands before making the opening or add removable pieces of framing to accomodate, which is a bit tougher when it comes to trim out.
