Results 1 to 10 of 11
    Nov 2010
    Philadelphia area
    40
    Default Doorway Trim Won't Fit, Alternatives?
    Pondering what to do about an interior kitchen passthrough, no door, that leads to a foyer where on the right side only I cannot fit a piece of 1x4 trim because the kitchen cabinets were installed too close to the wall (not my fault!! when the contractor used 12inch block not 10inch block we lost a couple of inches). As usual, the carpenter is the end of the line and deals with the problem at hand.
    I have thought of painting a faux trim piece all the way up until I can taper a piece of real trim.
    Something needs to go there, I want to put a header on top to match all the other headers.
    It's in the kitchen so there couldn't be a more visible spot in the entire house. It has to work. All ideas appreciated.
    1,522
    Default Re: Doorway Trim Won't Fit, Alternatives?
    rip the trim so it fits. its done every day on jobsites
    Nov 2010
    Philadelphia area
    40
    The problem with ripping it down is that the thickness of clearance is about an 1/8th of an inch.
    1,522
    the thickness of clearance?
    7,362
    I don't understand what you mean by thickness of the clearance either.
    If 1x4 trim is too wide and if you don't want to rip it, ger a narrower trim piece.
    Nov 2010
    Philadelphia area
    40
    There is only an 1/8 inch space between the wall and the kitchen cabinet drawer when it is opened. I have some pics but this system keeps saying its not a valid extension, but it is a jpg within the dimensions and file size, so what's the story with that?
    Nov 2010
    Philadelphia area
    40
    Ugh... I put some pics on a web page here...
    http://www.handpaintedwoodsigns.com/kitchen.html
    So to clarify the problem, the clearance between wall and cabinet when open is an 1/8 inch.
    1,522
    either rip the trim down or adjust the drawer front to give more clearance
    Nov 2010
    Philadelphia area
    40
    so in the end, i decided to use a thin strip of ply that came with the cabinetry, cut it the width of the trim, and fitted it into place, im the only one who notices. i hate it though. but i have new challenges to tackle elsewhere. thanks all.
    Nov 2013
    You can put a vase at the door or Other favorite decoration.If you are interested,You can design something Change some pattern.Escalator handrail
